Posted 3/28/2008 08:02 (#343670 - in reply to #343435) Subject: RE: Small irrigation pump - Would a sprayer pump work?
central - east central Minnesota -
I have a compact utility tractor (45hp) that can run the pump. No need for an additional engine. Need it for watering trees if / when it gets dry. Been loosing too many the last 2 yrs. Takes 8 hrs to do a 350ft run @ 1½ in water, if I can find a pump close to those specs -
