Posted 3/27/2008 23:01 (#343507 - in reply to #342390) Subject: Re: Tired of it saying, 0" OFFLINE and.....
North Dakota
One other thing to watch out for is implement drift. If the skip/overlap is consistent on one side or the other you may have to add an offset in the setup. I am finding when installing the control box the more solid that it is mounted to the tractor the better the system seems to respond to cab movement. Also install the updated firmware in the 500 lightbar (ver. 3.00).
