NW Washington | Get the spark set so that it does not kick an break your arm. Don't know what to tell you other than making sure you have spark, gas and compression.
You are lucky you have a Rumley 6 and not one of the Rumley Oil Pulls with the massive flywheel you have to stick a bar into to turn over the engine.
This link has a picture of a Rumley 6 http://www.antiquetractors.com/content/yph146.htm | |
