| no question about it, "GO WITH THE INSIGHT"!! they have there stuff all working on kinze now and we put the system on a JD this spring too so i can't see why it could be used on the white? I can't see you folding the markers, or adjusting the fan speed through the moniter though? Thats not how the GTA II works i don't believe? After seeing the insight and the air clutches you won't be disapointed thats for sure!!!! Take it out and use it for guidance, yeild moniter, spray controller, the options are nearly endless with the insight!!! | |
