WCIN | There was a bar available through CIH for the Magnums. The top end bolted ttowards the top right of the cab were the mirror usually is, and the bottom end bolted on about half way down the right front post, about where jp's showing his monitor. Then CIH had a twisted flat piece of still that clamped around the bar. On our 7220 I had the monitor on top of the flat piece and the control box bolted undereath. Also the control box was right in front of the gear shift, which I thought was nice for shifting markers after upshifting. | |
