Posted 3/23/2008 01:25 (#339924) Subject: To bring "Cal. Numbers" to the top...
IL
......soooo... if I understand it right, I would leave the cal number the same on the flowmeter entry, but us the conversion factor when figuring the flow thru the orfice. If I want 55 gal per ac of 28% applied, then I take 55 X 1.13 ( factor for 28%). = 62. correct?
May need to get bigger orfices.
