Posted 3/22/2008 19:18 (#339626 - in reply to #339612) Subject: Re: Hard 12-0-0-26 in bottom of tank?
Wheatley, Arkansas
We had that happen too. Blend the liquid back into the chunky tank, hook up your pump with the discharge going into the top of the tank and let it circulate, the bigger the pump the better, may even have to aim the discharge hose at the last few chunks, the warmer the temp the better and quicker the results. Poly -N will do his too. A real PITA.
