roaming | The Pro600 uses the Voyager2 format, so that's the format you'll use to export (through the Device Setup Utility). You can create either a grid or polygon prescription, but the polygon style is recommended. If you export a grid prescription, the Pro600 has to convert it from grid to polygon on-the-fly, and this is very resource-intensive. You may notice slow performance from the display. Your level of detail is up to you. | |
