Posted 3/18/2008 21:21 (#337012 - in reply to #336846) Subject: RE: Garmin 17N - will track new WAAS Sats?
Cedar Rapids, Iowa
That completely depends what version of code it has on it right now. If it has old code (with old WAAS info), it just won't get the correction info. Raw GPS is a lot less accurate than a WAAS corrected signal. Just update the code and it should behave fine with the new WAAS satellites.
