| As Ed Boyson says, it works extremly good. I installed a 500 RTK EZ-Steer last year and was really surprised. It reacts almost like an Autopilot cause you have not to turn the steeringwheel so much. It was a little bit hard to calibrate, but after a few trials I got it. If you use it with the 500, I can submit you a vehicle configuration. Axle to antenna distance was the critical value.
Bruno | |
