Central Kansas | Don't run any you have mentioned but do have a Deere with the floating hitch and wouldn't consider any other way. Will say that if you happen to go acrossed a terrece at an angle, part of the wing that is crossing the top, will be out of the ground and kinda look like everything is going to fall in a heap but once you are over it, things come back to normal. Go with the floating hitch and you won't regret it! | |
