Southwest Ontario Canada | We use the same combos on a 9x20 Kinze both for corn and beans. It has worked very well for many years for us. Currently we are building an 18x10 (two rows offset 9x20) to split the corn row for beans and would like to try 10 inch wheat next fall. Will only use a coulter on this setup. Met a fellow in Ohio who plant beans through his 10 inch wheat in June when heads are in dough stage, might want to try this also but will require building another specialized type planter/drill. Also we are just down the road from you near Shetland Ontario. | |
