West Texas | Well, I'm stumped.
I need to run a hydraulic motor off a TM155, but the hydraulic lever will not stay in position. Normally, there is a detent to hold the valve open, but it doesn't appear to be functioning. The troubleshooter suggests adjusting the detent, which sounds sensible, but then it fails to mention items like WHERE do I find the adjustment? HOW do I adjust it? And also, HOW MUCH?
When I used the hydraulic motor last, I didn't have this problem, so I'm pretty sure merely adjusting the detent will not solve the problem.
The detent works fine with the engine 'off'.
TIA for any ideas or suggestions.
