south east SD | No tubes here also. Have a set of tires on the front of our 8300 MFD that pulls the planter and there are getting thin. Had a slow leak and called the tire guy, he came out and looked at the tires and said they aren't worth nothing so I'll put in some "tire snot" and run them. 2 years later they are still doing there job and never leak!! The "tire snot" is a pink looking stuff from Texas oil fields that comes in a 5 gallon pail with a plunger and hose that you hook to the tire and pump the snot direct into the tire after you let all the air out. Works like a charm!!! | |
