SW Ohio | Working on my 85 W900, fuse panel needs new brass clips that grip the fuses, come in a bank of 18 to a strip. KW dealer gave me a kit but it only has four in a strip, 18 strip has another brass bar riveted on for amperage, four does not. Searched Terminal Supply, NAPA, and googled for an hour but can't find anything. KW kit has steel inserts in the brass to give stronger grip, all others I have found don't have the insert. IS this too old to find parts for or am I missing something? Gotta go play in the snow but will try to get pics later. | |
