Eastern VA. No such thing as too many Magnums. | If its just a sensor, its easy. It could be the gaskets between the shift valve body. That takes a little more work. You'd have to take the steps off. The problem is that when you remove the shift cables, the adjustment body usually gets messed up and you need to install a new cable too. At least that's how my 5 were. We usually run in muddier than average conditions. |
