Newburgh, IN | Are you sure the transfer case has any fluid in it?? I am tearing into my 05 3/4 ton tomorrow because the pump has worn a hole in the side of the case, causing it to leak. I caught it soon enough, so I dont think it is hurt. There are several different fixes for this problem if that is the case.
Check out http://www.dieselplace.com/forum/index.php You need to register, but there is a lot of information for the "pump rub" issue.
