Search Forums | Classifieds (138) | Skins | Language
Putting Greenstar in a Hagie
tedbear
Posted 3/3/2008 04:28 (#324373 - in reply to #323947)
Subject: RE: Putting Greenstar in a Hagie
The steering or guidance will probably be OK if the rig is on the Deere's list.
The mapping portion is another story. The connection between the two would be via a 9 Pin computer type cable which is part of the 4600 harness. The fact that the system is CAN is not the problem.
The problem will be if Field Doc can work with the 4600 data strings. It is my understanding that Field Doc can work with the Raven 440, 450 etc. which are single product controllers. Since the 4600 could be multi-product, the data strings are different (they need to be able to work with up to 5 products). I don't believe Field Doc can handle these data strings at this time.
The 4600 could communicate with members of the Ag Leader family since the Ag Leader consoles have a setup menu where you pick the controller that you are using. The 4600 may not be specifically listed but its data strings are now the same as the older Raven 750. With the older PF3000 or Advantage you would only be able to log one of the products but the communication does work.
Edited by tedbear 3/3/2008 04:30
