JD 2600 and The Mojo
paconsult
Posted 3/4/2008 15:47 (#325657 - in reply to #325153)
Subject: Re: JD 2600 and The Mojo
We have been successful in using the GS2600 terminal with ArroUniversal BEELINE RTK controller and receiver for autosteering which is also ISO compliant. The autosteer function now just appears as an icon on the screen as a menu option, somewhat like when you plug the GS2600 with say ISO compatible Dicky John implement controllers. This has happened in QLD, Australia, customer has 10 BEELINE systems in mostly green machines. In theory as the Mojo RTK system is ISO compatible this also should work.
