Well, they are getting pretty old, so it's pretty much a matter of condition and what you think it is worth to you to use. I'd say it could bring anywhere between a few hundred and maybe $5,000 or so. There's probably $4000 worth of difference between new and junk blades and bearings. We have a 953A which is pretty much the same thing only 25' and I'd say it's worth about $3000. I think I have it a little cheaper then that on the net worth. We've used it a lot and will probably keep it around because it works much better then the big disks for seeding waterways and other small jobs as well as for working terraces. We have a 42' Krause we just bought, and I think going to the field with it and the 25' gets almost twice as much done as the 42' alone in some fields, because the 25' will work out the terraces just as fast as the 42' can.
Edited by plowboy 2/24/2008 20:58
