Central Iowa | Have you pulled any of them out and actually looked at them? Last year I bought a four-year old 1770 JD planter. I thought the units had too much up and down play so I bought a few bolts and bushings from JD before checking the old ones. I discovered the old bushings and bolts weren't worn and the new bolts basically rattled around in the new bushings just as bad as the old ones. They just don't fit like you would expect them to. Has anyone else had this experience?
Edited by DeereFarmer 2/8/2008 09:43
