speed with ez-steer / ez-guide plus
Posted 2/1/2008 13:20 (#298547 - in reply to #298540)
Subject: RE: speed with ez-steer / ez-guide plus
I use an EZ-Guide+ with EZ-Steer on my non power steering 218 3-wheeled Coupe. I've run 16 MPH with it and steering seems to be as good as it is @ 12 MPH. Either the 500 or 250 should be even better due to their 50Hz refresh rate, as opposed to the 5Hz on the EZ-Guide+.
There is absolutely no way that I can steer manually and even come close to the performance of the EZ.
