Hagen Brothers farms,Goodrich ND | I need advice on connecting EZ guide plus with EZ steer and remote plus a boom switch to my sprayer tractor.
Is the 52033 splitter cable the only way to connect both the remote and boom switch to the EZ guide plus lightbar, or is there another place to connect.
Also is the black and white wires in the weather pak connector of the 52033 cable the correct place to connect the boom switch ?
A pinput check of the splitter cable shows that the black wire in the weather pak connector connects to the #5 ground pin in the 9 pin connector that connects to the light bar and the white weather pac wire connects to the #4 data terminal ready pin in the 9 pin connector which are the two pins that connect to a boom switch. TIA.
Edited by Jon Hagen 2/1/2008 22:10
