Search Forums | Classifieds (76) | Skins | Language
Outback S need more serial ports
tedbear
Posted 1/21/2008 04:14 (#288446 - in reply to #288382)
Subject: RE: Outback S need more serial ports
A splitter may work for you. I am not very familiar with your exact equipment but one thought that comes to mind is that the GPS out settings for both "split" units would need to be the same.
Generally autoboom products require a fairly fast GPS ( 5 Hz for example) in order to work properly. If this is the case in your situatuion, your other device (the Ipaq) would need to be able to accept the information at the same speed and with the same strings active. This may or may not be a problem for you.
