| DO NOT DO IT! Raven invicta firmware versions later than 4.34 will produce big errors at unpredicticable times. I tried them all and had to reload 4.34 in the 210's we have. Call the Raven precision rep in your area (the guy in the field, not in the office) to see what he says. Lightbar firmware versions past 2.8 seem to be related to the tilt sensor in the lightbar. Upgrading the lightbar firmware will not hurt, but is a waste of time. Unless you have severe slopes you should turn the tilt comp off. I will try the next version of Invicta firmware (after 4.5) to see if Raven has found the problem. | |
