Search Forums | Classifieds (173) | Skins | Language
Insight & Autoswath possibility?
Posted 11/16/2007 22:07 (#239594)
Subject: Insight & Autoswath possibility?
Using an AL Insight & Autoswath you can presently turn on spray boom valves & row unit clutches (both elec & air) via electronic signal. Insight turns them on/off if it detects you've been there before (sprayed or planted).
So-can an Insight raise an implement (chisel plow? planter? etc?) once you pass over an area you have already marked, meaning either planted or tilled? Using the same electronic signal could activated electric SCV, couldn't it? In other words, let the AutoSwath raise/lower your implement for you.
Maybe this is already done is old news? Or-why is it impossible?
