Search Forums | Classifieds (33) | Skins | Language
What program do you use for creating scatter plots with GPS
CB In The Cab
Posted 11/16/2007 18:41 (#239488 - in reply to #239419)
Subject: Re: What program do you use for creating scatter plots with GPS
Central To Everything and Close to Nothing
Hey Stu, I did this a long time ago for another project but I beleive we did this with the Hyper Terminal program that comes with Windows (Accessories, Communications). You will have to set up the port for the serial connection that your reciever is connected to and the baud rate etc. Once you have that set up, under the Transfer menu there is a capture text option which will create a text file to save the data to. From there you can import that text file into excel and create your plot. Hope this helps.
