Northern Illinois | I have built and used a power cord for the 25-pin connector on an Ag Leader which allows me to use the Ag Leader for both my planter and spayer. I would like to now use it for a 28 Tool-Bar Applicator. I would like the wiring numbers for the 25 pin-connector so I can hook a flow-meter to the 3000. It says in the Ag Leader manual that you might be using pin no. 8, 9, 21, or 22. The flow-meter is a Micro-Trak that uses three wires. Again, according to the Ag Leader manual (pg. 2-95) this can be hooked up. It will record the flow, but will not allow me to make any adjustments.
Please give me an information you might have.
