Search Forums | Classifieds (198) | Skins | Language
252 to CIH yield monitor?
torn
Posted 10/1/2007 14:23 (#212766 - in reply to #212751)
Subject: Re: 252 to CIH yield monitor?
roaming
what firmware version in the monitor? anything prior to 31.4 is not compatible with XP, so you're wasting your time. You'll have to update firmware (which may require a different monitor altogether) or use WAAS or VBS.
Otherwise, it's 8N1 NMEA 4800 at 1hz, GGA and VTG turned on
