Posted 9/27/2007 13:51 (#210668 - in reply to #209672) Subject: RE: Original Greenstar fault code
Guelph Ontario Canada
If Fault Code 110 and your problem with the fore / aft not saving showed up at the same time, I would investigate the power source. Switched power problems can cause settings not to save. As others have said 110 is pretty generic.
