Search Forums | Classifieds (85) | Skins | Language
EZ Guide Plus / Few Satellites
Ont. Farmer
Posted 9/24/2007 21:26 (#208926)
Subject: EZ Guide Plus / Few Satellites
When using my EZ Guide Plus I am losing my guidance and having the message "Few Satellite" flash on screen. Start monitoring satellite tracked and it ranges from 6 to 1. When going in the field I will lose guidance 2 or three times the length of a field.
I am using version 4.11 and switched to new satellites. Minium satellites needed is set at 4. Angel is reduced to 4%.
Seems like it is losing the Satellite signal. I am located in Ontario about 70 miles from Detroit.
Antenna is mounted on top of cab.
Thanks in advance for your help.
Tom
