| If you can use a narrower tarp ( 15x50 ) try to get the latest billboard signs when they are replaced. I bought several from a guy changing advertising for $20 each. They're pretty heavy material, and have a continuace seam instead of eyelets that are prone to focusing the stress in windy conditions. I run a piece of square tubing in the seams, and then tie down. MUCH less wind problems on hay. | |
