I think one question you did not address: how much growth was on the hay when the lime was applied? I would presume very little, but I don't want to presume anything. So, that might be a question you want to respond to. My gut feeling is that with 3 inches rain, the lime should definitely be washed off. If the hay was only 4 inches or less when lime was applied, I would respond in the same way. So, to restate my question... how much growth was on the hay when lime was applied? |
