Search Forums | Classifieds (2) | Skins | Language
EZ Boom Problem 854 Rogator again
Noble1
Posted 8/22/2007 10:33 (#191365)
Subject: EZ Boom Problem 854 Rogator again
Arco MN
Ok Finally got this system work perfectly early this summer. When it works it is a great thing.
I guess lately the system with give the "Flow Valve Driver Failure"
It would always do this but it would only do it when you slowed way down and it couldn't get the flow that slow. This was fine but now it is doing it even at normal speeds. When it does do this it won't control the rate and we just have to adjust the sprayer speed to get the rate right.
My thinking is it is either a communications problem with the flow valve, or the flow valve itself.
Just looking for any other insight I can get on this.
My plan of action is to check all wiring and make sure that looks good. Look for any broken wires or corrosion.
If that all looks good and we still have probelms I might put the old raven back in and see if that has any problems.
