Posted 6/5/2006 08:59 (#17219 - in reply to #15902) Subject: RE: PF Advantage Question
Northwest Iowa
i change the application mode on ours. when i do that the acres and loads are "fresh". they have planting,spraying, etc modes built in. if you do this you will have to change the width of your operation to calculate the correct acres.
