Near Intersection of I-35 & I-90 Southern Mn. | Scroll down below to some of the past posts for several discussions concerning this situation.
Since the EZ-Guide Implement switch needs to utilize a relay anyway it would be easy to use another relay to trip the other device.
Using two relays (one for each device) is the safest way to handle a double hookup such as this. By using two relays each system will remain electrically separate from the other.
You will need the Trimble cable listed in the posts below or an equivalent. This cable is sometimes referred to as the "hammerhead cable" as it has one connector that splits to three. This cable is used with both the EZ-Guide+ and the EZ-Guide 500. |
