Washington Co Ks | I use Ritchey ear tags that have a contrasting color layer sandwiched in the center. You scrape off the top layer and the middle color will show as long as the tag lasts. The tag is kind of tough to cut.I use a Dremal type grinder to grind through the top layer. I've used these tags to record information such as speed and other settings for spraying or appling AA and use cable ties to attatch them to the machine that way the information is right there and I don't have to look it up next time. | |
