| I wish I could get a hold off a corn picker. Other then silage ground ear corn is the best feed for cattle. We used to pick about 10,000 bushels years back an pile it on the ground. Grind it an feed it til it was gone. Used to have a wet bin that we would put high moisture corn in. Set the combine with the sieves wide open so there would be more cobs an stalks in there. Worked good for feed. | |
