Posted 7/27/2007 20:50 (#179354 - in reply to #179314) Subject: Re: AFS & Insight are they the same unit?
roaming
I assume you're talking about the AFS Pro 600 and the Insight monitor. No, they are not the same. Several differences, including the hardware itself and the software that each display uses. You can't use an Insight to replace a Pro 600, and you can't use a Pro 600 to replace an Insight.
