Monroe Oregon | Don't know about hooking into a Raven 460, but been using MID-TECH systems for years now. Check out www.TeeJet.com and go to the guidance equipment and there is PDF that will show you what all the SmartpadII will do. The Swathmanager would definitely be one to look into. Have it on both sprayers using a Legacy 6000. Couldn't imagine spraying without it. What GPS antenna do you have? Mostlikly a RX350p or RX370p. Do to the WASS decommission you antenna will need to be reconfigured. I did this on both of my 350p's today and is very simple to use. All the instructions and program is on the web site, and I just hooked my laptop to the antenna in the cab and performed the new set of sat info in about 5 min. Any questions just ask. | |
