Denhoff,ND right in the center of the State | If you have holes corroded through the floor it is from not cleaning it out regularly, believe me alluminum dont rot out if it is cleaned and washed, our family has been in the livestock hauling business for nearly 60 years, I have been custom hauling for 17 years and never had a trailer floor corrode through yet, but we clean and wash ours. If you have steel and alluminum together with no barrier inbetween them you will get corrosion then, but shouldnt with alluminum against alluminum. Hog manure is the worst their is and is why a trailer should be washed regularly. |
