Search Forums | Classifieds (46) | Skins | Language
green seeker
willmarman
Posted 6/19/2007 23:31 (#164633 - in reply to #164331)
Subject: Re: green seeker
Monroe Oregon
Been using a Green Seeker for two years now. I like the system a lot. Very easy to use and also set up. Just using a sigle sensor for NDIV on grass seed. I collect data in the spring during a 24D application and then the customers fieldman takes the data to build a VR percription for growth regulator about a month or so latter. The comments from the fieldman is that the Green Seeker does a great job and feels that the data is just as good as the plane. The advantages to the Green Seeker is you can use it when ever you need to. I also sell the system here in western Oregon and getting a lot of intrest in it. It does make a lot of sence with the cost of inputs on a solid rise. I know we aren't using the system to it's full use, but we are still learning
