| Is anyone else running a Deere 4700 sprayer with an EZ Guide Plus, EZ Steer, and Trimble 252 reciever with Omnistar HP?
I can't seem to get it calibrated right. Very slow to correct going across the field. Will drift offline by about 1 foot and then slowly start to come back. The angle per turn is set low and the aggressiveness is set around 135%. Also the wheel base is set at 60 inches shorter than actual.
Normal spraying speed is about 14 MPH. Can't engage it at anything less than 10 MPH because it will osciallate back and forth violently.
Gotta be a way to make it work, but I haven't figured it out yet.
Thanks
Andy | |
