Search Forums | Classifieds (77) | Skins | Language
Trimble headacke
   Forums List -> FAQ & SupportMessage format
Paul Schmidt
Posted 5/30/2011 23:15 (#1799911)
Subject: Trimble headacke
Beeville, Tx
I have trimble rtk with fmd monitor installed on 8310 jd. Its been four years and the dealer cannot stop it from going into a perodic weave. It will work perfect for a day or two or a week then for no apparent reason it will go into a 3to5 inch weave pattern for a short distance or may be all across the field. Turn around and go back and it may work ok or may be not. The dealer and Trimble together have changed out the entire system one component at a time in numerous attempts to correct this problem. All signals are 100% while this problem is occuring over and over again. The last time the tech was in the cab with me it was throwing a horrible fit and he disconnected his laptop and said I would just have to drive it my self when this happens then he left the field. I am a striptiller and driving the tractor myself is not always an option.
