Posted 4/15/2011 02:49 (#1725120 - in reply to #1723122) Subject: RE: Prolapse ? 800 lb feedlot heifer
southern saskatchewan
Can you get the vet to give her some freezing. Sometimes they mix something and the freezing is permanent. Can you treat and change her diet? Seems like when that happens somethings not quite right. In the past had some yearlings like that but never had any of them not make it. TLC and a little luck she should pull through.
