Kingston,Mi | Midwest Ag plan books have several different plans to form bunks. Page 8-22 of the Beef Housing and Equipment Handbook MWPS-4, has the dimensions and no instructions on how to cast and assemble the bunk, but it appears to be 2 sections cast flat then erected. Then the floor is cast to connect the previous 2 castings.
Several other designs for wood and concrete, bur if it is concrete that you need, then commercial is probably the way to go. The tilt up design just appears to have lots of work and frustration in the the completion. | |
