Posted 1/15/2011 11:15 (#1550383 - in reply to #1549875) Subject: Re: Treating Founder in beef steers
northwest tennessee
You might could trim his feet but would need a table to do it right. That might help but not sure on that either. If you think acidosis caused it you could mix feed grade limestone in the feed. I mix it in mine at the rate of 25#s to a ton of feed and the calcium acts as a buffer plus I need more calcium with the DGs.
