Posted 8/29/2010 15:08 (#1337424 - in reply to #1336427) Subject: RE: Cobett Waterer inside building??
I'm going out on a limb, if it's installed correctly for 'your' area, it probably won't even ice over more than just a 'skim' in the coldest weather you have.
The only problem I can think you might have will be the cattle 'drooling' water in the building and creating a mess that won't dry or ice on the ground around the waterer that won't melt due to no sunlight and no wind.
