SE Nebraska | You need to find someone you are comfortable in working with. You may need to shop around and it may take a couple years to build a trust in someone. I have been using FuturesOne in Lincoln and have been satisfied the last couple of years. Again alot of it is the person you are working with and you both understand each other and are on the same page. I also use John Roach. | |
