Search Forums | Classifieds (61) | Skins | Language
Auto Steer. Which One?
waterbottle
Posted 3/9/2007 02:06 (#117042 - in reply to #116865)
Subject: Re: Auto Steer. Which One?
South Australia
What type of differential GPS are you using at the moment? From what i read you are using two sprayers? Is this correct? Do you use the sprayers in the same field at the same time? Do all you sprayer operators know the geography of your fields (ie rocks, waterways, where and wherenot to spray). Do you currently use autosection control? Are your spray controllers the same brand or are they different? How big is your budget? Will the auto steer only be used on your sprayers or will it be moved over to a tractor? all important questions, answer them so we can give you better advice. Cheers
Waterbottle
